BeatNavy
Jul 18 2018, 06:45 AM
Looking for the left / right TOP cooling tin pieces (the big pieces) from a 2.0 that are in decent shape. Would prefer to not have to modify 1.7 pieces if possible. Also, 2.0 intake runners.
Shipping in this case to zip 49508.
KevinW
Jul 18 2018, 08:50 AM
I’ll check when I get home from work. I think that I have an extra set of runners and maybe some tin.
Kevin
DRPHIL914
Jul 18 2018, 10:18 AM
I may have a set , but I got my redone set from Bruce stone, along with all the tin top and bottom, except for a few under pieces I got from Kevin(rhodguy), even all my other heater tubes etc Bruce has everything.
Phil
ClayPerrine
Jul 18 2018, 11:55 AM
I have a set of tin and the runners.
But this is Texas, so they were cut for AC.
Let me know if you are interested.
BeatNavy
Jul 18 2018, 01:03 PM
Thanks, fellas. I'll wait to see what Kevin has, and then maybe circle back to Clay and/or Phil. Darn, A/C sure sounds nice right about now, but I'm not sure I'm ready to go that route on cutting up the other body parts. What part of the tin gets modified / cut for that?
Phil, couldn't tell if you do or don't have the parts
Sounds like you're not sure?
Thanks again, guys.
ClayPerrine
Jul 18 2018, 01:32 PM
QUOTE(BeatNavy @ Jul 18 2018, 02:03 PM)
Right front corner, where the accelerator cable hole is located. The compressor is below the battery tray. I use the compressor and mounts from ICEAC. It is designed for the type IV motor. To pull the motor, you take the compressor loose and set it in the battery tray.
914werke
Jul 18 2018, 04:09 PM
I have the runners
HERE
BeatNavy
Jul 18 2018, 04:58 PM
Thanks to all that replied, including Rich. Just purchased driver's side tin and intake runners from Kevin. Still looking for passenger side, although I am interested in the one you have, Clay. I'll send PM.
DRPHIL914
Jul 18 2018, 08:27 PM
QUOTE(BeatNavy @ Jul 18 2018, 03:03 PM)
Thanks again, guys.
Well , i guess that was a bit ambiguous. i meant i may have a set of intake runners- no tin sorry! bit Bruce will
BeatNavy
Jul 19 2018, 03:41 PM
Still looking for passenger side tin. I'm going to pickup Clay's with the AC cutout as one day I would LIKE to do that.
For now I still need a regular, 2.0, passenger side tin.
ClayPerrine
Jul 28 2018, 08:02 PM
Your tin is in transit.
Betty wanted me to say thank you for the new carpet for her car. You buying the tin paid for it.
