I made myself a way to get my front trunk to open in the face of catastrophe today and took pix to document it. But then decided I didn’t really want that cat out of the bag with a lot of photos about opening my car at night. So instead, decided to caution folks ahead of trips they may be taking.
Down below it says I have a TR6, and a common woe for those Is a broken hood latch, so I have a safety wire. Many do.
Faced with 5000 miles of travel in the 914 with my wife in June, my big worry was a failure of the front trunk release cable. Especially since her stuff and the tool bag were up front. The manual tells how you can get around such a failure by removing part of the front end. Ughhh. As it happened , only the back trunk failed with my stuff in it, so that was OK.
I was worrried because after replacing ALL of the rubber seals, that front trunk closed kinda hard and proud. She had to push down on the trunk above the latch while I pulled the handle to get things opened on hot days.
Anyways there are simple precautions you can take, as with the TR 6 hood release, and if you hit the road, I suggest you give them some thought. Basically you run an extra cable to the site of your choice.
