rosenfe
Jul 21 2018, 06:04 PM
My trim has come loose on the top at union and at the bottom strip and at 90. I see the tabs the trim fits into.I have crimped them a bit to make a tighter fit,but I may be missing a tab on the bottom of window. Can the tab be replaced with window in?Im assuming there is a hole in body for tab to insert。Is this correct?Anything else I can do to secure trim?Adhesive etc
Coastal6
Jul 21 2018, 06:54 PM
Yep.. you are correct. There is a small hole in the windshield frame that the plastic clip snaps into. Don’t think there is any way to replace the clip with the windshield installed.
Super glue ?
DRPHIL914
Jul 21 2018, 08:25 PM
i would say it depends on the gap. you might be able to put a new clip in. the new clip will have a pin sticking out, if you pull that, press the clip in place and then press the pin into the clip, as it slides in press it all the way in it will expand the back side of the clip and lock it in to place.
rosenfe
Jul 24 2018, 07:56 PM
If my clips do not hold trim securely and I don’t want to take window out,would useing an adhesive such as 3m window adhesive to the chrome be a no no?
Mikey914
Jul 25 2018, 09:54 AM
I would avoid super glue, You can use 3M weatherstrip adhesive. They also make butyl strips that can be used to hold stuff down. The idea is something that will not react with the paint and still hold it in place. Check at your local automotive paint supply store.
DRPHIL914
Jul 25 2018, 09:59 AM
QUOTE(Mikey914 @ Jul 25 2018, 11:54 AM)
that is a good tip.
rosenfe
Jul 25 2018, 12:40 PM
Thanks
rosenfe
Jul 25 2018, 12:44 PM
I was going to use 3m window weld .The chrome piece would be glued to glass not body.Window weld is used to glue window to body.
dr914@autoatlanta.com
Jul 25 2018, 12:49 PM
no way without the windshield removed, one should always replace the clips when the windshield is out to make sure that the chrome strips stay in place.
Really the only thing you can do now is put some black silicone under the strip and tape it down until it dries
QUOTE(rosenfe @ Jul 21 2018, 05:04 PM)
