QUOTE(tazz9924 @ Jul 21 2018, 09:30 PM)
So ive been having this problem lately where the fuse that powers the brake lights keeps popping and when it does it turns the gen warning light on. The alternator (Subaru swapped) keeps going like nothing even happened but im left without brake lights. A little diving found that the brown and gray wire that is T’d to the brake lights at the brake light switch is also connected to the alternator in the middle terminal on the connector. Im gonna unplug it to test wether it keeps popping the fuse or not. Any ideas as to what could be happening?
See if the fuse pops when you put the car in reverse. The backup light switch was superseded to a 915 switch, if the shifter is even slightly mis-adjusted, the pin will push too far in and the switch will short to ground, blowing the fuse. Ask me how I know... 70 with new switch and a mis-adjusted tail shifter.
