QUOTE(milwlandrover @ Jul 26 2018, 06:23 AM)
(I can not figure out the heater and the OR did not know how it worked either)
The heater is worked by the lever between the seats. Pull it up, and the flapper valves on the exhaust open up and allow the engine cooling fan to push warmed air from the heat exchangers into the cabin. Pull it up all the way, and the heater blower fan comes on and pushes more air into the heat exchangers, which makes more warm air go into the cabin.
brand new tires on what I believe are aftermarket wheels.
Rivieras. If they have a Bug offset, they will only fit 165-width tires at best. If they have a 914-friendly offset, the rims will be deeper in the fenders, and you can fit 195s (sometimes even 205s) without significant rubbing on one outer rear fender or the other.
It had dual exhaust which I thought was strange as I thought the 914 had single exhaust.
It did, but there were several aftermarket mufflers that had two exhaust tips. And some people remove the muffler and just stick cherry bombs or megaphones on the end of the stock heat exchangers, which is generally not a good idea.
The roof appeared to have been redone - the vinyl removed and the top painted flat black.
There was no vinyl on the roof. It had a "pebbled" texture painted on it, satin black in color. It looked a fair bit like the vinyl that was optional on the "sail panels", but it wasn't vinyl. It's not uncommon for people to sand the roof panel smooth and then paint it body color. Flat black is an interesting choice...
He wanted $8500.00 and he came down to $7800.00. I think I came out ok. Thanks for your help
Sounds like a pretty decent price for a running driving 914. Depending on the rust.
--DD
