MikeM
Jul 25 2018, 07:21 PM
Hi all...74 2.0 liter with Djet...
What size are the fuel lines in the engine compartment that connect to the fuel rails?
Need to replace a couple...
Thanks
76-914
Jul 25 2018, 10:58 PM
IIRC, 8mm connecting the 2 fuel rails together *mm from pressure reg to return line and 7mm from fuel rail to injector.
I've had wine tonight and might be prone to error.
914Sixer
Jul 26 2018, 07:17 AM
Make sure you do NOT used the braided hose UNLESS you are going for 100% original. Porsche replaced them on the fuel line recall. Use modern fuel line.
TheCabinetmaker
Jul 26 2018, 07:22 AM
What Mark said. It should be ethanol rated too!
JeffBowlsby
Jul 26 2018, 08:03 AM
We could tell you the size but why don’t you just measure the fuel rail OD yourself?
The fuel rails are 100% accessible to measure without taking anything apart.
MikeM
Jul 26 2018, 10:08 AM
Because I don't have it apart. But thanks for your helpful comment.
Mark Henry
Jul 26 2018, 12:14 PM
5/16" SAE 30R9 FI hose.
Bartlett 914
Jul 26 2018, 12:22 PM
QUOTE(Mark Henry @ Jul 26 2018, 01:14 PM)
The FI hose is important. It is rated for higher pressure. Standard hose can work but you are taking a gamble.
