When I bought my roller 71 project, it came with the original 1.7 (which had developed a knock) with D-jet, and a 1911 which had been run on carbs. Unfortunately, the carbs had been removed. I have sourced a set of Weber 40 IDF carbs from a World member and have gone through them to replace and clean up any suspect parts. I'm now in search of a low pressure fuel pump to mate up with the carbs. What options have you carb folks gone through and what seems to work well? I'm also curious to know if folks have used pressure regulators in their setups. Any particular recommendations? I would love to fire up the 1911 and see how it runs!
Thanks--Jesse.
BTW, I did a search and found a great thread on tuning the carbs, but not a lot on the pump used FWIW
