D-Jet Troubleshooting values:
TS1 – Air Temp Sensor – 242 ohms (expected 300 ohms)
Fuel Injector – cylinder 1 – 3.4 ohms (expected < 3.0 ohms)
Fuel Injector – cylinder 4 – 3.3 ohms (expected < 3.0 ohms)
Fuel Injector – cylinder 2 – 3.2 ohms (expected < 3.0 ohms)
Fuel Injector – cylinder 3 – 2.8 ohms (expected < 3.0 ohms)
MPS Primary Coil – 93.9 ohms (expected 90 ohms)
- -No continuity to the case from either lead
MPS Secondary Coil – 363 ohms (expected 350 ohms)
- - No continuity to the case from either lead
Accelerator Pump Contact Track:
- -Both #1 and #2 seemed flaky and inconsistent
ECU Ground – 0.00 ohms (expected < 0.5 ohms)
Trigger contacts assumed good – engine runs and idles OK
ECU Battery Power – Assumed good – Battery out of car
TPS Idle Contact – 0.05 ohms closed, infinity open (expected the same)
Start Signal – Assumed good, not tested, car starts – No battery in car
TS2- Cylinder Head Temp Sensor – appears to be open:
- Pin 23 to ground – infinity
- Pin 23 to CHT Lead 0.00 ohms (good)
- CHT Lead to ground 0.00 ohms (good)
- **Seems that the CHT itself is open.
-Aaron
