QUOTE(Tdskip @ Aug 2 2018, 01:56 PM)
Are the clutch kits the same part all the various displacement engines?
I think so but want to double check.
Looks like no one actually answered YOUR question.
Yes, the clutch is the same on all 914s, and 911s up through 1969.
Parts you need:
Clutch disk
Pressure plate
Throw-out bearing
Throw-out bearing plastic bushings
Throw-out arm pivot bushing
Pilot bearing
Pilot bearing felt
Flywheel lock plate
Rear main seal (I put them in every time I do a clutch. It's cheap insurance).
2 CV joint gaskets
Muffler gaskets (2.0 is different from 1.7/1.8)
Optional
New shift rod bushings (tail shift and side shift use different bushings)
Trans front seal.
If you have any questions... let me know.
