ClayPerrine
Aug 4 2018, 01:48 PM
Looking for a working heated rear window. I got one with the car, but it was damaged while bringing it home.
If it didn't come from the factory with one, I wouldn't bother. It's not needed here in Texas.
Will consider one from anywhere. Shipping costs are not a problem.
Thanks in advance.
Clay
914_7T3
Aug 6 2018, 08:25 PM
cary
Aug 6 2018, 10:49 PM
Hmm .........no ones coming to the party ?
I think I have 2 of them on the rack. Do they work ?
I can have Super In Law run continuity tests on them Thursday.
914Sixer
Aug 7 2018, 06:45 AM
Continuity is the problem. My -4 came from Montana so it had one but the window has a few gaps from cleaning over the years.
bdstone914
Aug 7 2018, 08:23 AM
I have a couple too that may work and need to run the continuity test. I would not buy one on Ebay when they do not state that it was tested. I would sell a good one for $100. Shipping is kind of expensive.
Bruce
bdstone914
QUOTE(cary @ Aug 6 2018, 09:49 PM)
300 Ohms side to side is the spec.
Krieger
Aug 7 2018, 08:46 AM
Clay. Can these be repaired?
914sgofast2
Aug 7 2018, 06:41 PM
QUOTE(Krieger @ Aug 7 2018, 07:46 AM)
Permatex sells 2 types of rear window heater repair kits. One for repairing a loose/broken off tab (Part #21351), and one for repairing a break in the heating grid lines (Part #09117)
cary
Aug 8 2018, 12:01 AM
I've used this product a couple times with good success.
https://www.frostfighter.com/index.htm
sixaddict
Aug 8 2018, 06:51 AM
Have one ...not tested as yet but car had 55K miles when it was hit. Seems you probably have located several. Let me know if you need one after the others play out.
ClayPerrine
Aug 9 2018, 06:14 AM
I am interested in one that doesn't need repair. The car is down because the window is out of it.
Send me some pictures!!!
914_7T3
Aug 9 2018, 12:37 PM
Is there an early vs late designation for rear windows? Just curious.
ClayPerrine
Aug 9 2018, 03:46 PM
I don't think so. There are only two part numbers in PET. One for with heat, and one without. And the with heat is superseded to the number for the one without.
914_7T3
Aug 9 2018, 05:12 PM
QUOTE(ClayPerrine @ Aug 9 2018, 02:46 PM)
Clay, can you PM me with any that you find that you will not be purchasing? I like the idea of having a spare just in case. My car came with one and its referenced on the COA.
I just don't want to poach on your deal as its your thread. It pisses me off when people do it to me. Thanks.
ClayPerrine
Aug 9 2018, 08:31 PM
QUOTE(914 7T3 @ Aug 9 2018, 06:12 PM)
Thanks. I appreciate you being courteous. You can use this to get one for you once I get one.
gulf908
Aug 10 2018, 06:05 AM
guys
thanks for your timely advices on the heated back window
as a result of some horse trading,I acquired a heated backlite recently which has the regulation ratty wires and the missing side clip
I want to repair this one as the date seems to be the same as my car's build month
Does anyone have a link to the Permatex repair kits pls ?
TIA
Dennis
ClayPerrine
Aug 10 2018, 09:05 AM
Did any of you do the testing on a windows yet? I am ready to buy the first one that tests good.
914_7T3
Aug 10 2018, 10:38 AM
QUOTE(ClayPerrine @ Aug 10 2018, 08:05 AM)
and I'm interested in the second.....
PotterPorsche
Aug 10 2018, 09:50 PM
I have 1 located in Northern California. $200
PotterPorsche
Aug 10 2018, 10:28 PM
With fluke set to resistance the. Number varies my fluke is set to auto all depend on hard you press the wires
PotterPorsche
Aug 10 2018, 10:51 PM
