I was told that if you have a 1.7 Case that 2.0 heads won't fit right .. They have to be machined to work .. also that 1.8 heads on a 1.7 case is a better fit .. Also VW makes a Cylinder head that is have the cost and less work to fit up to a 1.7 case ..
I'm running into a lot of different guys with a bunch of different options to rebuild a type4
Things I'm thinking on changing
1) The Heads
2) the cylinders and Pistons
3) the cam
So with these 3 things what is the best combo ... ??
