jandro62
Jun 14 2005, 04:02 PM
I've got my hands on a single wire vdo temp sensor. From what I've read in other posts, it screws into the taco plate, and I'm going to need some gaskets. If my motor didn't come from the factory with a temp sensor, do I need to figure out a way to drill and tap this thing into the taco plate, or is there a good source for 73+ taco plates?
Thanks,
Alex
Jun 14 2005, 04:04 PM
QUOTE (jandro62 @ Jun 14 2005, 03:02 PM) |
or is there a good source for 73+ taco plates? |
that reminds me ...
whatever happened to the billet taco plate project?
Andy
Mueller
Jun 14 2005, 04:08 PM
I'm having some programming issues with my CNC mill
Mueller
Jun 14 2005, 04:10 PM
markb
Jun 14 2005, 04:11 PM
purty...
hmeeder
Jun 14 2005, 04:42 PM
Joe Bob
Jun 14 2005, 05:15 PM
The VDub guys use a sensor that sticks in the oil dipstick hole.....pretty ez install.
lapuwali
Jun 14 2005, 05:58 PM
There's another one that replaces the drain plug.
Joe Bob
Jun 14 2005, 06:00 PM
James....does that one work like the head temp sensor/thermocouple?
Mueller
Jun 14 2005, 06:22 PM
QUOTE ("*" @ Jun 14 2005, 05:00 PM) |
James....does that one work like the head temp sensor/thermocouple? |
both terrible ideas*..
*I gotta say that so I increase my chances of selling my billet parts when I get around to making them, hahahaha
lapuwali
Jun 14 2005, 07:50 PM
It works just like the oil temp sender. It's a thermistor, varying resistance with temp. I have one on my Type 3, as it doesn't have a taco plate. As far as I know, other than the threads on the plug and the length, it's no different that the 914 sensor.
The 914 CHT is also a thermistor, just a higher temp range. The Westach/VDO aftermarket CHT ring-around-the-spark-plug senders are thermocouples, which generate a very weak voltage based on temp.
