Sold - $14,250
1973 2.0 Bahia Red - $15,000 obo
2.0 appearance group package parts:
2.0 Fuch's including a 5th/spare
Center Console with gauges
Fog lamps
Chrome Bumpers
Front sway bar
Rear sway bar included, but not installed
GA Engine Code
Recently rebuilt Top End 2056:
Engine Specs:
Ceramic Coated AA Piston Heads with customization done by HAM -Len Hoffman($1539)
SSI 2.0 Heat Exchangers
Leistritz Muffler
Carb Cam - Mild, but too aggressive for FI
Dual Weber 40 IDF (Spain) bought from Aircooled.net with additional pre purchase work done by John at ACN setting them up.($950)
Tangerine Racing Dual Carb Sync Linkage($330)
123 Bluetooth Distributor ($475)
Clearanced 2.0 rockers with solid spacers and Bus 10mm swivel feet adjusters
Additional Items:
All new shift bushings from firewall to transmission
CHT setup from Aircraft Spruce under #3 spark plug
AEM UEGO AFR
Dual post Oil pressure switch
Tangerine Racing SS fuel lines and Fuel pump
Ford Starter Relay and push button start
911 brake Master Cylinder
Turbo Tie Rods
All gauges and switches work.
Repainted in Original Bahia Red. Sail panel vynil removed. Targa top painted to match.
Going for Euro look so no Porsche engine grill lettering. 914VW Porsche rear badge
Rust has been repaired/ Longs were not in bad shape but Brad Mayer Stiffing kit was welded in. Fiberglass rocker panels.
Rebuilt transmission at Dr. Evil clinic Jan1 2018.
Will post more pictures and a video of cold start and drive.
