QUOTE(914werke @ Aug 17 2018, 02:16 PM)
Not a buyer but is that the bare shaft or including a 2nd gear set
That is the bare shaft that you can swap 2nd gear around on. The standard F and GA shafts all have the 2nd driven gear as part of the shaft and thus not change able. I also have an E gear for the 904 shaft that I will be listing once I know for sure a build I am doing wont need it (depends on buyer). These shafts and gears are most desirable to racers and large engine conversions. I often convert 901 to 4 speed and lower second gear with these so that it becomes the new 1st gear. So, instead of an F as a 1st gear, you get an E which is far better and usable.
