QUOTE(Shredhead @ Aug 21 2018, 09:20 AM)
I had the same issue. I think injunmort is on the right track, as I went into the lever, didn't really find anything amiss, but when I put it back together it started working again.
Rusty grounds....hot grounds.....hot wire means no wire. That's what I found.
Between rusty relay grounds and a really thin trace on the relay board, bound to fail after 40+ years.
I had to rewire the ground completely from the harness through the tunnel to the harness.
Trace each wire back with a DVM set on OHM's.
Good luck.
