AndrewBlyholder
Aug 22 2018, 02:20 PM
I've been feeling a lot of vibration on the freeway in my street 914. Had all the tires rebalanced and checked the front wheel bearing tightness. (Did tighten one side down a bit.) No shimmy in the steering wheel now, but still feeling a vibration in the car, so it must be something coming from the back end, but with newly balanced tires, don't know what it might me. I think of rear wheel bearings as whining when they wear out rather than exhibiting any shimmy. Am I wrong on that? Could the rear bearings be worn out? The CV joints look fine on the exterior. Is it possible for a CV joint to get so out of balance than it transmits a shimmy into the car?
Any thoughts or suggestions would be appreciated.
Andrew Blyholder
Cairo94507
Aug 22 2018, 02:25 PM
Check the rear suspension ears and CV joints.
rfinegan
Aug 22 2018, 03:22 PM
center your wheels on the hubs
AZ914
Aug 23 2018, 04:32 PM
Check the bushings on the rear control arms. I had a shimmy that would come and go on the freeway and that was the culprit.
AndrewBlyholder
Aug 28 2018, 12:49 AM
All good suggestions. Thanks, I'll check them all out.
Andrew
TheCabinetmaker
Aug 28 2018, 05:52 AM
If you feel the vibration in the steering wheel, it's most likely the front. If you feel it in your butt, it's in the rear
Aug 28 2018, 11:03 AM
Broken engine or transmission mounts?
Rob-O
Aug 30 2018, 11:52 AM
I had this recently. Just after I got new tires. The tire jockeys balanced it and put all the weights on the inside of the rim. I guess they’re used to doing that now with all the flush faced rims they deal with. Had them balanced by someone else that was old school and they put weights on the outside of the rims as well (Fuchs 2.0L rims) and it completely eliminated the issue.
xperu
Aug 30 2018, 01:18 PM
QUOTE(rfinegan @ Aug 22 2018, 04:22 PM)
Look at Tangerine Racing under
Transmission (Rear Hub Centering Ring), ths might help or resolve your problem. Mike Kelly
mgphoto
Aug 30 2018, 01:23 PM
5 lug conversion from 4 lug?
Rear disks not centered after rear wheel removal?
dr914@autoatlanta.com
Aug 30 2018, 02:09 PM
after exhausting all possibilities, do check the cv axles.
tire balance
tire balance
tire balance
bent wheel
loose swing arm
cv axles
