BK911
Aug 23 2018, 09:24 AM
First time in over 10 years of ownership.
Heading home from the auto parts store, and engine just stopped firing.
No place to pull over, but fortunately I was going fast enough to drift to a safe spot.
After poking around for a couple of minutes, an old timer pulled over and offered to help.
"Dont know much about them fern cars, but do you need any help?"
Yes, could you give me a ride home?!
Got home, hooked up the trailer and went to get her.
She would fire up a second or two, then bog down and die.
Almost like something was in the tail pipe.
Will check for spark, but...
It "feels" like a fuel issue, so tonight I start looking at the fuel pump.
FI is loooong gone, after market fuel pump with EMPIs.
dr914@autoatlanta.com
Aug 23 2018, 09:30 AM
at least with carbs it is an easy fix!
QUOTE(BK911 @ Aug 23 2018, 08:24 AM)
VaccaRabite
Aug 23 2018, 11:00 AM
Are you out of gas?
Zach
mgphoto
Aug 23 2018, 11:10 AM
Check FI trigger points for oily residue.
TheCabinetmaker
Aug 23 2018, 01:47 PM
. Last line says fi loooong gone
Mblizzard
Aug 23 2018, 01:57 PM
Sounds like fuel.
I had a similar issue and my fuel tank had moved and kinked a line. Not a likey problem but it kept me stumped for a long time.
Aug 23 2018, 02:02 PM
that happens, every thing is fine until the fuel gets hot heating up the high pressure rubber line under the tank, folding it over and killing the engine. Wait a bit, the hose unfolds and you just drive off. Moral is to not make the lines under the tank too long and when installing no sharp bends
quote name='Mblizzard' date='Aug 23 2018, 12:57 PM' post='2641952']
Sounds like fuel.
[/quote]
BK911
Aug 23 2018, 03:30 PM
Only getting 2.1V to the fuel pump.
Using the stock wiring and jumped one of the FI terminals to ground.
Been working fine for ~8 years.
What could have happened?
Might take 12V directly there if need be.
BK911
Aug 23 2018, 03:31 PM
BK911
Aug 23 2018, 03:40 PM
Fuel pump relay?
How do I jump it out?
JamesM
Aug 23 2018, 04:04 PM
QUOTE(BK911 @ Aug 23 2018, 01:40 PM)
Fuel pump relay?
Whats the input voltage to the relay?
Did you try swapping the relay?
Is the relay making proper connection at the board?
Jumping the relay itself is pretty easy just a matter of inserting a wire in the relay socket between the 12V pin and the pin that runs to the pump, but not sure why you would want to as the ground wire you have in place place has it activated all the time.
BK911
Aug 23 2018, 04:19 PM
Ok, if I am reading the wire diagram right...
Term 86 input to fuel pump relay gets its power from term 87 output from power supply relay?
Tdskip
Aug 23 2018, 06:24 PM
Might it be worth just temporarily running a good source of 12 V to the pump to see if that takes care of the issue before you start any other electrical work?
Spoke
Aug 23 2018, 08:38 PM
Check out the schematic of the relay board below. For the fuel pump, If you want to run the fuel pump continuously even without the key ON then jumper pin 30 to 87 of the fuel pump relay. Careful as pin 30 is connected directly to the battery; no fuses and always powered.
You can try swapping the fuel pump relay with the heater fan relay on the end of the fuse panel.
cary
Aug 23 2018, 09:02 PM
Nice wiring diagram. I've never seen it before.
Spoke
Aug 23 2018, 09:54 PM
Also check the 25A fuse and make sure both sides of the fuse and the spring clips are clean. Fuel pump power goes through the 25A fuse.
Triaddave
Aug 25 2018, 12:37 PM
May seem kinda dumb but check the fuel filters. Old system may be clogged and would explain the start then stop issue...K.I.S.S. (keep it simple stupid)
BK911
Aug 28 2018, 07:09 AM
Fixed it!!
It was the power supply relay.
So fuel pump power goes through a fuse and two relays!!
Trouble shooting guide:
Check for 12V at pump. Zero volts!
Check fuse. 12V on both sides.
Check power relay. 12V at pin 30. 0V at pin 87.
Replaced relay and now have 12V at fuel pump.
Drink beer.
Repeat step 5.
