QUOTE(Dave_Darling @ Aug 25 2018, 10:14 PM)
Also note that L-jet does not "prime" the pump with a 1.5 second pulse when the key goes from "off" to "on" the way that D-jet does. L-jet runs the fuel pump when the starter is cranking, and also when the flap in the air-flow meter is opened.
--DD
Great advice Clay! Thank you for your detailed input. I learned more about the system. Battery 100%, but no buzz from the fuel pump.
Ok, so here is my progress with this. Followed your advice Clay and here are my results:
1. Pulled yellow wire, no start from pump.
So...
2. Checked the fuel pump relay (little black box by battery). Red wire leads to positive terminal is good. Checked the plugs, the black plug is getting signal, but I did not get a signal from this white plug:
Click to view attachment Can someone tell me the function of this white and black plug?
3. Thanks for ID’ing the oil temp wire. I thought it was that one.
4. White wire hooking up to the coil is ok.
Checked if the fuel pump is getting juice, and looks good on that end. Right now I have a feeling the fuel pump relay or pump went to 914 heaven.
Any other tips let me know. I will try again next weekend.
-Ed
