The engine runs great - once I figured out the starter CLANKING issue (last post) the car started! Runs smooth. All of the cylinders are 130+ lbs/sqi - YEA! So it seems that the odometer is correct at 20K miles.
When the engine runs, it runs VERY rich - seems to be vacuum related. So I plugged all of the holes and it still runs rich.
1. I know the Manifold Pressure Sensor is not working - failed the vacuum test (ordered the bellows from Tangerine.
2. The de-accelerator valve is not connected to the throttle body, the RIGHT ANGLE connector to the throttle body is missing...
Can anyone point me to a vendor that has that part? Hate to try and fabricate this part........
