potomacmidget
Aug 25 2018, 02:45 PM
Dear All,
I have a 1971, 1.7L 914, D-jet, original/stock with exception of the muffler system.
Purchased from a fellow board member here, very well sorted car - has been solid for like 5 years.
As of a month ago it starts fine, then after 30 minutes runs rough, backfires and then stalls. Has happened twice, managed to get home by keeping the engine rev'd at 2K RPM and then popping it in gear and keeping it in 3rd reving high, with backfires. Once it stalls very difficult to get it to start again. Both times it has been hot out, have not experienced this before, fuel pump is in the original position and perhaps vapor lock? (but never happened in the past).
Prior to the issues I pulled distributor, replaced the points, condenser, cap rotor, and reinstalled. I exercised caution pulling it an ensured I lined it up properly. I "did" adjust the timing post distributor installation (had to find the faded spots and repaint them) and I adjusted the throttle at the screw by the throttle body. System idled great at like 750 RPM and ran fine - but then the stalling problem previously described started.
I am thinking of the following could be issues:
ignition parts? new but a bad component maybe?
timing messed up? but not sure how it would drift as it starts fine
fuel pressure regulator issue?
CHT issue?
bad coil? acts up once hot?
bad fuel?
bad relay board or D-jet pressure sensor?
bad fuel filter?
Any help appreciated. After the first failure I found I had a leaking fuel injector, leaking from the injector itself(crack). I replaced the injector and it fired up fine, but then 30 minutes later it sort of goes demonic on me...so that was not the root cause.
Thanks in advance,
Reg
mark04usa
Aug 25 2018, 04:22 PM
Reg,
Your symptoms could well be due to hot weather vapor lock. I would recheck tune, be sure you have no fuel or vacuum leaks, and no fuel hose restrictions, but if the engine runs well until fully warmed on a hot day...vapor lock is a common problem. I still have the fuel pump in the original location on my '70 with D-Jet and had hot restart problems, but a change to Chevron premium fuel helped my car. So, be sure to use a quality premium gasoline.
Good luck sorting out
Dave_Darling
Aug 25 2018, 11:27 PM
Next time it tries to die, try removing the gas cap. If it sucks a bunch of air in and the car runs OK again, your evaporative emissions system is plugged up.
--DD
potomacmidget
Aug 26 2018, 05:18 PM
QUOTE(Dave_Darling @ Aug 26 2018, 01:27 AM)
--DD
Mark and Dave - thanks for the advice, I do question the fuel I got, and do have an intact (rebuilt) emissions tubing/charcoal canister, so that could be the issue. thanks again.
Reg
Ansbacher
Aug 26 2018, 05:55 PM
Been there- Coil, Coil, Coil!
Ansbacher
IronHillRestorations
Aug 26 2018, 08:29 PM
Fuel filter? Trigger points? Old electric components can get wonky when they get hot, but I'd change your fuel filter before I did anything. It sounds like it's getting plugged and then loosens up after the pressure is off
Racer
Aug 27 2018, 06:33 AM
I've had similar issues over the years:
1) crud in tank was getting into the fuel filter and clogging it, and would slowly cause the car to stop running. Wait 30 min or so, and car worked fine until the cycle repeated
2) relay board and fuel pump issues. Ran fine. would slowly loose power. couldn't keep running and stall out. Usually harder to restart and time to restart was more variable than in situation 1.
That said, each car is different.
potomacmidget
Aug 27 2018, 06:35 PM
QUOTE(Racer @ Aug 27 2018, 08:33 AM)
Thanks Racer and IIRC - will keep you posted.
iankarr
Aug 27 2018, 09:15 PM
QUOTE(Ansbacher @ Aug 26 2018, 07:55 PM)
Ansbacher
Symptoms are the same as what happened to my '73. Changed the coil and all was well.
TheCabinetmaker
Aug 28 2018, 05:57 AM
Definite sign of a failing coil
Racer
Aug 28 2018, 06:25 AM
On the plus side, while the board has diagnosed it as either a fuel issue or a spark (ignition) issue.. we all agree its getting plenty of the 3rd needed element. . . Air!
potomacmidget
Aug 30 2018, 07:59 PM
QUOTE(Racer @ Aug 28 2018, 08:25 AM)
Thanks again guys...on the pelican looking at coils and fuel filters!
euro911
Aug 31 2018, 12:15 AM
Change the components out one at a time, so you'll know for sure which component was the cause of failure
marksteinhilber
Aug 31 2018, 08:20 AM
It might even be the tiny braided mesh ground wire that connects the moving points mounting plate inside the distributor. They go bad and resolderingbthem is difficult and still may not re-establish a good ground connection. I’ve seen that first hand. On cars this old, every electrical connection including the ignition system is suspect.
