milwlandrover
Aug 26 2018, 03:40 PM
Both my '73 and '71 have crummy rubber adjustable side mirrors. what did the originals look like. I have seen pictures with round and rectangle and although both of my cars have (2) mirrors, I think the originals only had (1)
ConeDodger
Aug 26 2018, 04:07 PM
All years look like this...
Passenger side mirrors were required in some markets and available in all I think. The door already has the threaded nut in place.
Aug 26 2018, 04:17 PM
Early mirror has a hard bend. Mid year and later has a softer curve
ConeDodger
Aug 26 2018, 04:36 PM
True, there were changes. But short of dumpster diving at the pick n pull or hanging out in the classified, you’ll only find late mirrors.
GaroldShaffer
Aug 26 2018, 06:21 PM
QUOTE(ConeDodger @ Aug 26 2018, 05:36 PM)
Early mirror
Sep 7 2018, 12:42 PM
johnhora
Sep 7 2018, 01:49 PM
The mirror glass is also just slightly larger in the late style.
tmc914
Sep 7 2018, 06:32 PM
While on the subject of mirrors...
My passenger side is like a magnifying glass. It is almost unusable. Most mirrors say "objects may be closer..." mine should say ..."Objects appear closer...". Are there two styles of mirror?
Sep 7 2018, 07:00 PM
QUOTE(tmc914 @ Sep 7 2018, 08:32 PM)
You can always replace the glass with a regular piece.
tmc914
Sep 7 2018, 07:02 PM
[/quote]
[/quote]
Did not think of that, will have to put on my to do list. Thanks.
Sep 7 2018, 07:21 PM
[quote name='tmc914' date='Sep 7 2018, 09:02 PM' post='2646589']
[/quote]
[/quote]
[/quote]
914rubber has both sizes of glass. If you decide to switch it out, don't use a flat blade screwdriver to remove the plastic ring. It damages the edge of the stainless steel but do lube up the spring and nut located behind the mirror, under the base and all the pivot points on the arm.
Valy
Sep 7 2018, 07:34 PM
QUOTE(mepstein @ Sep 7 2018, 11:42 AM)
That is evidence of 21 murdered teeners!
Sep 7 2018, 07:42 PM
QUOTE(Valy @ Sep 7 2018, 09:34 PM)
Some give their lives so others might live.
Larmo63
Sep 7 2018, 07:50 PM
I like the look of the earlier mirrors better.
But that's me.
marksteinhilber
Sep 8 2018, 12:08 PM
QUOTE(Larmo63 @ Sep 7 2018, 06:50 PM)
But that's me.
Click to view attachmentI thought your favorite were those mustang mirrors!
Kaeferfreund
Sep 18 2018, 02:02 PM
@ mepstein
Is there some "interior" inside the mirror? Or just the glas and the plastic retaining ring/mirror gasket? Any differences between the early and the late style mirror interior?
Sep 18 2018, 03:09 PM
QUOTE(Kaeferfreund @ Sep 18 2018, 04:02 PM)
@ mepstein
Yes, the interior gaskets that hold the glass are different. I don't have them in front of me now but I'm sure there are pics online. You do need the interior gasket/spacer or the glass will rattle.
Dave_Darling
Sep 18 2018, 07:38 PM
There's a thread around here that shows the inside of the mirror. It's the metal case, a clear-ish soft plastic spacer, the glass, and the black retaining ring. The thread might be in the Parts Vault forum?
--DD
FlacaProductions
Sep 18 2018, 07:51 PM
Passenger and drivers mirror are the same, correct? Just one part number?
Sep 18 2018, 07:58 PM
QUOTE(FlacaProductions @ Sep 18 2018, 09:51 PM)
There was a different passenger mirror with a curved lens (that not everyone likes). 99% just take a driver side and flip it.
If you buy a used mirror, don't force it to move at the joints. They are often dry and corroded. Try dripping some light lube to see if you can get it moving again. If it won't move easily, take the mirror apart, clean and lube all the hardware. I have 20 mirrors and half of them have a little bulge at the back of the mirror because too much pressure was used to adjust the mirror.
FlacaProductions
Sep 18 2018, 08:39 PM
Thanks, mepstein - good tips.
Also - I found good info on the minutiae of mirrors here:
http://www.p914.com/p914_mirrors.htm
euro911
Sep 18 2018, 10:48 PM
My mirror looks like this
Kaeferfreund
Sep 19 2018, 02:16 PM
QUOTE(Dave_Darling @ Sep 19 2018, 03:38 AM)
--DD
Would be helpful to find it
Is there anybody who offers some reproductions of the plastic spacer for early mirrors? I didn't find one....
914Rubber ?
AA ?
Sep 19 2018, 02:53 PM
QUOTE(Kaeferfreund @ Sep 19 2018, 04:16 PM)
--DD
914Rubber ?
AA ?
I have not seen it for sale but I need about 18 of them.
I’m pretty sure the spacer that is a thin white frame is for the late mirror and the white full rectangular spacer is early.
dr914@autoatlanta.com
Sep 19 2018, 03:11 PM
we make the black surround in 5 and 5.25 out of a silicone mold so it works but is not so pretty
QUOTE(Kaeferfreund @ Sep 19 2018, 01:16 PM)
--DD
914Rubber ?
AA ?
Sep 19 2018, 03:14 PM
Does anyone make the white spacers. They seem to have a shorter lifespan than the black surround. Most of mine have crumbled away.
@mikey914 QUOTE(dr914@autoatlanta.com @ Sep 19 2018, 05:11 PM)
--DD
914Rubber ?
AA ?
GaroldShaffer
Sep 19 2018, 07:24 PM
QUOTE(mepstein @ Sep 19 2018, 04:14 PM)
--DD
914Rubber ?
AA ?
I could use about 6+ of those white spacers myself.
orthobiz
Sep 19 2018, 07:36 PM
There's something about the magnification that occurs when you use a regular mirror on the passenger side, always seems to look enlarged, I agree. I didn't know that true passenger mirror were available with different glass..
According to Brad Mayeur, you could ask the dealer back in the day to put a passenger mirror on when the cars were new. When I refreshed my two original paint cars, I elected to leave them alone without adding the passenger mirror. I love the visibility compared to modern cars and don't seem to miss them.
mepstein's picture of all the mirrors made me smile!
Paul
seanery
Sep 19 2018, 08:21 PM
I have a handful of mirrors that need restored, so I could use some as well!
euro911
Just a thought ... maybe someone could shoot a decent sample to Mark Whitesell to see it they could be easily reproduced
Sep 19 2018, 08:27 PM
QUOTE(euro911 @ Sep 19 2018, 10:21 PM)
I'd be happy to. I'm sure I have at least one good sample of both types.
Mikey914
Sep 19 2018, 10:59 PM
Yep more than happy to do so. Just need a good sample.
-Mark
euro911
Sep 19 2018, 11:03 PM
I have a couple of mirrors that could benefit from new innards
Kaeferfreund
Sep 20 2018, 11:38 PM
QUOTE(Mikey914 @ Sep 20 2018, 06:59 AM)
-Mark
Mark, that sound's good. Now I hope anybody from the 914world community delivers the patterns you need.
If you are able to reproduce those missing parts for the early style mirrors, you will get an order from abroad,too.
Greetings from
Sep 21 2018, 06:55 AM
QUOTE(Kaeferfreund @ Sep 21 2018, 01:38 AM)
-Mark
Greetings from
The thin border spacer is the early smaller mirror. Most of mine are cracked or in pieces or brittle and ready to crumble.
One of each is in the mail to 914rubber.
Jett
Sep 21 2018, 09:13 AM
Hello, do you happen to have an early mirror for sale? my mirror’s internal bolt and stud are stripped.
cheers
Sep 21 2018, 10:43 AM
QUOTE(Jett @ Sep 21 2018, 11:13 AM)
cheers
Like most of what I buy, these are projects. I'm not going to sell anything until I go through each mirror and figure out what's usable and in good shape. I know I need about 20 to make 5 good pairs for myself. I would call Garold, Bdstone, camp914 or 914 limited if your mirror is good but you just need the parts. Many of my mirrors have a bulge in the back from trying to turn the mirror by force or a crack in the shell near the arm from using a screwdriver to remove the black outer seal. These mirrors can be fully serviced and made to work and look like new but they need care or they lock up and forcing them to move will break them. Pretty much the same goes for the rest of the car....
euro911
Sep 21 2018, 01:08 PM
QUOTE(mepstein @ Sep 21 2018, 05:55 AM)
Thanks, Mark E. ... and Mark W.
... Mark S.
I guess I'll have to dig up my old mirrors so I can order the correct inserts for them (I think I have both early & late ones)
Kaeferfreund
Sep 21 2018, 03:09 PM
QUOTE(mepstein @ Sep 21 2018, 02:55 PM)
-Mark
Greetings from
Well, I understand it that way, that the early style ones just have the border space. Until now I thought they also had a more stable interior.
So, wouldn't it be better to create a more stable one like that for the late style mirrors (lHS of your pic) for this ones , too? Would be an improved repro then.
Sep 21 2018, 04:29 PM
QUOTE(Kaeferfreund @ Sep 21 2018, 05:09 PM)
-Mark
Greetings from
I don’t have it in my hand but it’s not just a flat spacer. It has a ridge that holds the glass in place. I don’t thank no we need better, just need the right piece.
Kaeferfreund
Nov 13 2018, 02:45 PM
QUOTE(Mikey914 @ Sep 20 2018, 05:59 AM)
-Mark
Mark,
what's the current status of that reproduction? Any -good- news?
Nov 13 2018, 03:08 PM
QUOTE(Kaeferfreund @ Nov 13 2018, 03:45 PM)
-Mark
Mark,
I did send mikey/mark a sample of both inner and outer plastic pieces.
I have plenty of outer frames since they don't seem to fall apart like the inners but they are sure a lot of work to reinstall. I wonder if they harden up over time.
Kaeferfreund
Nov 15 2018, 02:14 PM
QUOTE(mepstein @ Nov 13 2018, 10:08 PM)
-Mark
Mark,
Hi!
I have a follow up question to your hint :
" If you decide to switch it out, don't use a flat blade screwdriver to remove the plastic ring. It damages the edge of the stainless steel (
understood)....but do lube up the spring and nut located behind the mirror, under the base and all the pivot points on the arm."
So if a screwdriver isn't such a good idea, how could you remove the old mirror glas without damaging neither the metal casing nor the plastic holders and the black rubber sealing ring? Any pictures here or in another discussion?
