rosenfe
Aug 27 2018, 10:33 AM
On my 74 2.0,when turning key ,power turns on,red and green lights come on,but starter will not turn.Jumping starter directly engages starter and it will continue to engage starter for a day or so and then no engagement.Car is in good shape,wires to starter look good and are tight.
Any suggestions.would this be a good candidate for mark henry relay?.Battery is good,starter works well.
North Coast Jim
Aug 27 2018, 10:37 AM
Had the very same issue after a complete rebuild of the car. It wasn't a hot start issue sometimes it just wouldn't start. New red top battery checked good.
Found Mark Henry's relay addition and all is well since. Can't hurt either unless your a concours car. Do it !!
Triaddave
Aug 27 2018, 10:55 AM
The same problem on my 75 car, turned out to be ignition switch where key goes in. It was a $40.00 ish part. The steering wheel,turn/wiper stuff all comes out,cir-clip too all to get to the hidden screw. not as hard as it sounds. it fixed my car in about 1/2 hour
Mark Henry
Aug 27 2018, 11:01 AM
The stock bosch solenoid needs a full 9v to kick in, likely due to old wiring, corrosion, resistance you're not getting a full 9v.
Likely my fix will solve the issue, but you should still clean all your grounds, terminals, connections, etc.
Link at the bottom of my signature.
rosenfe
Aug 27 2018, 11:27 AM
I will try relay first. Replacing switch is more work.I have done it several times.
rosenfe
Aug 27 2018, 07:56 PM
My starter has 2 yellow wiires going to seperate Jacks. Mark Henry’s pics show onlyone yellow. Anyone know what to do with that second wire and hooking up relay
