Attached are 4 pics to help describe what is going on. It all started when I needed to replace the spring at the carburetor. That is when I noticed the following issues.
1. The hole the spring goes into has elongated (over 45 years) and I am worried it may pull through and will need to replace the linkage (looks like that would be a PITA because the linkage looks press fitted attached. See pic#4.
2. The Air filter housing to the carburetor has been crushed to go from 2.5” to 2.25”. See pics#1 and 3.
3. The Air filter inlet from carburetor has been cut to fit over sized air filter inlet. See pic#2
4. The entire assembly looks like it needs to be replaced because if you look closely the plastic or rubber “U” fitting with a smaller “Y” fittings attached there are small cracks
Something obviously is not stock, should not be held together with duct tape. Not sure what I should do next. Best guess is replace hose fitting to one that starts out at 2.25” and ends with 2.5”. Is that even an option?
Click to view attachment Click to view attachment Click to view attachment Click to view attachment
