dwillouby
Aug 30 2018, 09:40 AM
Hello,
I need the plug in connector /wires to connect to the reverse switch on a 02 Boxster S trans.
Anybody have one?
Thanks
David
bdstone914
Aug 30 2018, 05:23 PM
QUOTE(dwillouby @ Aug 30 2018, 08:40 AM)
Hello,
Anybody have one?
Thanks
David
Did you try Porsche ?
dwillouby
Aug 30 2018, 07:10 PM
Of Course...
They will sell the complete harness.
Only need the connector.
bdstone914
Aug 31 2018, 04:58 AM
QUOTE(dwillouby @ Aug 30 2018, 06:10 PM)
Of Course...
Did you check with Porsche? Or download PET for free and go thru section 9 to see if they show the connector part number. Many connectors. Post a picture of th connector or switch. The connector is probably not made by Porsche and available elsewhere. Or post of Pelican Boxster forum. You can check with dismantlers too.
yellowporky
Aug 31 2018, 08:39 AM
I went through the same process a few years ago and finally found a website that sells the connectors, pins and boots. I will try to find the site and post it for you.
Chris
timothy_nd28
Aug 31 2018, 09:22 AM
I'm totally in the same boat. I have tried several Porsche dismantlers, once they understand what connector I was after, they soon realize its a 5 dollar part and not worth the trouble on their end.
bdstone914
Aug 31 2018, 03:19 PM
Here is a pic of the switch Does no look like too unusual connector. Very similar to a fuel injector connector.
Try belmetric.com
bdstone914
Sep 1 2018, 05:20 PM
This should work.
@dwillouby
davesprinkle
Sep 1 2018, 08:19 PM
That is a two-terminal connector made by AMP, PN 963040-3. It is part of the AMP Junior Power Timer line of connectors. It can be purchased at digikey.com, along with the crimp terminals. You'll need a crimp tool.
bdstone914
Sep 1 2018, 09:06 PM
QUOTE(davesprinkle @ Sep 1 2018, 07:19 PM)
Or buy it from O Reilly with wire leads installed for $6 .
davesprinkle
Sep 1 2018, 10:11 PM
QUOTE(bdstone914 @ Sep 1 2018, 08:06 PM)
Yes. Disadvantage is that the pigtail approach requires a couple of ugly and unreliable butt-splices. And a crimp tool.
bdstone914
Sep 2 2018, 10:43 AM
QUOTE(davesprinkle @ Sep 1 2018, 09:11 PM)
Or cut , soldier, shrink wrap the wires.
dwillouby
Sep 5 2018, 11:30 AM
Thanks,
Will stop by and pick one up.
No problem connecting as have electronic engineering background.
David
ClayPerrine
Sep 6 2018, 02:49 PM
That is a standard Bosch fuel injector plug. You can buy them as kits direct from Porsche.
I keep a full set of them in my parts stash.
