QUOTE(DRPHIL914 @ Aug 30 2018, 05:54 AM)
QUOTE(Mblizzard @ Aug 30 2018, 09:26 AM)
QUOTE(vw_porsche @ Aug 30 2018, 05:14 AM)
Nothing like waiting till the last minute.
Super excited to drive some twisties with all new ball joints, turbo tie rods, shocks, and control arm bushings.
Drives better if they are on the car?
Me I added rear sway bar, Koni adjustables, and a bit of negative camber.
Oh and a new engine. Cant wait for the drive.
mike, what did you do to add the negative camber? is that a change in the shims? I have been told I need more negative camber as well., I should do this while the car is up to get motor put back in.... - just put new bushings on my rear stock sway bar as well. - found my squeak I had too, it was the drop link bushing on right side- it was put in new a couple years ago, needs some lube I guess.
Noted edited due to units.
For me as I will be doing mainly street driving, my goal was to put another-1/2 degree camber on both ends, giving you -1/2 degree front and -1 degree rear.
As you are limited by the shims, you will have to come up with a combination that gets you to what you want to have. Stock camber is 0 to 15 minutes.
A 1mm shim results in approx. 10 min (0.166667 degree) change of camber.
I was able to use my various combination of shims to get about -0.3 degrees on the rear. So it would be best to know what your current camber, but assuming it is between 0 to 15 minutes (0 and 0.333 degrees) you can measure the shims you have and try to come up with a combination that takes out between .5mm and 1mm of shims. There is almost always positive camber on these cars so the resulting amount of negative camber on the 0.5mm would likely not be extreme and taking out a full mm should be acceptable.
I had +1.4 degrees (84 min) in mine so I took out a lot of shims! Someone please help me verify that taking the shims out increases negative camber!
Mark position of rear axle control arm on base plate and remove center bolt. Loosen remaining bolts only slightly. Change shims between control arm bearing and body to change camber angle. With camber to correct specifications tighten bolts, install center bolt and tighten.
