QUOTE(JeffBowlsby @ Aug 30 2018, 08:33 PM)
Early VIN 74 (with the silver dot gauges) was mounted on the fuel tank like the early cars.
Late VIN '74 was mounted to the passenger side, engine bay, aft firewall common to the rear trunk, using a special strap bracket. Look for the threaded stud on the rear wall.
Betty's car has a build date of April of 74. It does not have the silver dot gauges, but it had the charcoal canister in the engine compartment on the back wall. There was no stud for it, just a nut and bolt. So I don't think this is a hard and fast rule.
Because of the AC compressor, I relocated the ECU to where the charcoal canister was, and put the canister on the battery tray. I did it to keep the FI harness away from the spinning compressor clutch. Unlike the FI harness, If the hoses for the charcoal canister get cut, the car won't stop running.
