QUOTE(sjhenry1075 @ Sep 8 2018, 04:00 PM)
QUOTE(Rand @ Aug 31 2018, 02:59 PM)
I'd forego the fuel lines and brakes since you only have one long weekend and the most urgent thing is getting it to fire.
With a freshly charged battery, does it turn over when you hit the starter? That's the first thing to deal with. If it cranks but doesn't fire, that's very different than if it doesn't crank at all.
The car cranks but does not fire. How do I know if it’s getting fuel and spark? Before it was easy to tell cause it was leaking from all the fuel lines.
Take a can of carb cleaner and spray it in the intake. Then try to start it with your foot flat on the floor. If the ignition system is working, the car will either try to fire or fire up and die.
If it doesn't fire, start looking at the ignition system. Pull the coil wire and hold it close to a ground. Then crank it and look for a spark. If you see one, replace the cap and rotor. The rotors can sometimes burn a hole through them and dead short the ignition to ground.
If it has no spark at the coil wire, check the points/condenser/electronic ignition system. I just recently found a bad condenser that caused a no start condition on a car my father owns.
If you get spark to the plug wires, try a new set of plugs and repeat the carb cleaner test.
If the ignition system is OK, then we can start on the FI.
Thank you for the help! I’ll do those and get back to you
