i took this stuff apart almost a year ago and cant remember it all! this 4 prong pig tail should have a plastic thing it goes into right? i think i remember it falling apart on disassembly - but i dont rember what it is or what it supplies.
bdstone914
Sep 2 2018, 08:02 AM
Fuel sender connector. Nice over spray on the wiper motor wires. You should have a similar connector for the four ny-tied wireds to the wiper motor.
DRPHIL914
Sep 2 2018, 08:11 AM
thanks Bruce- having a heck of a time since i didnt take pictures of this or make notes, and yes there is a mess of overspray under there- i may not get this all back together to work- i can drive with out a blower or water squirters but i would like wipers- rainex will help lol! what is the secret to getting the clamp on thst holds the sider wireon the bottom of the blower?? i got it on but then could not get the box back into the slot had to tey and force it a bit and the clamp popped off! i am about yo just leave those in the open setting and the heck with the slider adjustment!
tmc914
Sep 2 2018, 08:58 AM
QUOTE(bdstone914 @ Sep 2 2018, 10:02 AM)
That is an awesome blown up picture of the wiring diagram. The one I have is so small and when I blow it up the numbers get bury. Where can I buy a large copy or get an electronic copy that is readable to my older eyes?
bbrock
Sep 2 2018, 09:27 AM
I think those wires with overspray actually go to the blower and the wiper wires have spade terminals (at least on my '73). when you get a connector, this thread might help figure out the pinout: http://www.914world.com/bbs2/index.php?showtopic=331912
Nice, just ordered 1 for my 1973 and only $19.95, thanks for the info.
DRPHIL914
Sep 2 2018, 11:07 AM
QUOTE(bbrock @ Sep 2 2018, 11:27 AM)
wipers have spade, but you are right, i checked closer at the wire colors and they are the blower wires, so the longer wires that are darker are for the fuel level sender unit. so i just need to find a black plug thing that holds the wires
rhodyguy
Sep 2 2018, 11:20 AM
is this the one? fresh air fan plug. check the wire colors against what you have. red/white stripe, white/green stripe, 2 whites. Is your fan functional?
DRPHIL914
Sep 2 2018, 11:38 AM
yes thats the ones that have overspray, missing the black holder part also need to make sure if i plug it in with out the black part that i have it in correctly, but looks like due to the length of the wires it would be hard to put in wrong
worn
Sep 2 2018, 09:42 PM
QUOTE(DRPHIL914 @ Sep 2 2018, 06:41 AM)
Try lacquer thinner carefully on the wires, rubbing with a cloth or paper towel. A lot of times the overspray will clean off.
cary
Sep 3 2018, 07:44 AM
QUOTE(DRPHIL914 @ Sep 2 2018, 10:38 AM)
I think the terminals would have a hard time staying in with the vibration from the fan. We've tore down a couple harnesses, I'll see if the 4 holers are in the terminal box.
