With all my dodads I'm at 55 points, without slicks! I guess what I am asking is there alot of peeps in zone 8 competing in AR? Who are they, besides Deiter?
Then my next question would be setup, who do you guys recommend for a top notch suspension setup and allignment? Preferably in Riverside or San Diego counties.
Front susp components: Hollow front torsens, PMS Delrin bushings, weltmeister adjustable sway, custom valved RSR struts with 19mm raised spindles, decambered elephant ball joints, monoballs, turbo tie rods, PMS bump steer kit, Brembo GTP lightweight brakes
Rear susp: body stiffener kit, beefed up inner susp mounts, boxed trailing arms, PMS delrin bushings, adjustable Konis, 190lb springs, PMS rear toe adjuster kit, Brembo GTPs
Thanx...Marvo
