To all very helpful 914-World readers.
Car was parked in 1988 - not moved since - just started Resurrection in June of this year.
I just started working on the ignition switch - it would not energize starter. NP, I used a jumper for the past few months and ordered a replacement switch. Yesterday I tested the switch on the bench, it worked fine. Installed and still would not energize the starter.
The seat-belt 'safety-switch' has been jumpered, testing at this junction there is an open circuit between the ignition connector and the seat junction of the two Yellow wires.
Question: Is the wire between the ignition plug and the seat junction a solid wire?[u] Or, is there a junction block between the two measurement points?
While I started to run this wire down I noticed that there was hay in the fuse area, so I dropped the fuse panel and found a very large mouse nest. May take the rest of the day to clean this up.......very dirty little critters....
