jim_hoyland
Sep 4 2018, 11:16 AM
How are these removed ? I want to powder coat the 4 clips and so far it’s not as easy as I thought. And, I’m doing this out of the car....
BPic
Sep 4 2018, 11:18 AM
Snap Ring pliers is what I used.
TheCabinetmaker
Sep 4 2018, 11:20 AM
I just slide them off the side. I think there is a mystery tool to remove them. At least that is what the two holes suggest to me. Maybe snap ring pliers
dlee6204
Sep 4 2018, 11:27 AM
QUOTE(BPic @ Sep 4 2018, 01:18 PM)
Works like a charm
rstover
Sep 4 2018, 12:40 PM
QUOTE(jim_hoyland @ Sep 4 2018, 12:16 PM)
Take two small punches or something that will fit in the holes. Kinda works like chop sticks. Just squeeze them together and slide off. It makes it very easy.
ClayPerrine
Sep 4 2018, 01:08 PM
The factory had a tool that would hook over one side of the clip, and force it down and over the other side. But after 40 years, the plastic is a little more brittle, so I use snap ring pliers.
JmuRiz
Sep 4 2018, 01:36 PM
QUOTE(TheCabinetmaker @ Sep 4 2018, 09:20 AM)
I just slid mine off the side
76-914
Sep 4 2018, 01:40 PM
I’ve extras if you need one, Jim. Kent
rstover
Sep 4 2018, 01:47 PM
jim_hoyland
Sep 4 2018, 03:21 PM
QUOTE(dlee6204 @ Sep 4 2018, 10:27 AM)
Works like a charm
That did it ! Soon as the pressure is relieved the clip slid off
jim_hoyland
Sep 4 2018, 03:25 PM
Now for the last question : After the 4 clips are off, can the front piece be removed separately for painting ?
Don’t want to pull the whole fresh air blower.....the unit in the picture is not mine. Mine is still mounted in the car....
bmtrnavsky
Sep 4 2018, 03:36 PM
Following... My gas tank is out this would be easy to do for me right now.
rgalla9146
Sep 4 2018, 03:43 PM
QUOTE(bmtrnavsky @ Sep 4 2018, 05:36 PM)
Remove your wiper assembly too.
Perfect time to lube the wiper shafts.
bmtrnavsky
Sep 4 2018, 03:57 PM
QUOTE(rgalla9146 @ Sep 4 2018, 01:43 PM)
Solid plan. It's just a good idea to do certain things while certain parts are out.
