So I am putting my Aux Oil Cooler back in place and had ordered a thermostatically controlled fan, but I don't remember how it was hooked up(yes I did do it a couple years ago) .
there are the 2 wires, a positive and negative coming out of the fan, and this has to pass thru the thermostat switch. What I am wondering is , it looks like the positive goes directly to the battery, and the negative passes from the ground point or negative on battery thru the switch and then to the fan, OR is it the other way around?
Phil
this picture was taken before we dropped the motor and disconnected it all- the bottom right you see a red button, this is the thermostat control - wiring goes thru this to the power source- but which way?
