QUOTE(Mikey914 @ Sep 6 2018, 07:02 AM)
Foam pad goes under the carpet. We have not made it yet. Working on a molded piece in correct "yellow" foam. It's a prtty simple process, just need to get it off the list.
mark
Also we are starting to add the tire tie down grommet.
Mark, I would like you to make one that is made out of a better material, more sound and heat reflective, insulation but not water absorption, like the 1/2" dynapad for trunks - could you cut it with your pattern to fit under the stock carpet, if so i would like one! for the trunk it would make sense to have a reflective surface due to heat transfer from the motor and transmission and exhaust under it.
Phil
