SierraNevada
Sep 5 2018, 07:22 PM
What are these calipers original to?
davep
Sep 5 2018, 09:02 PM
Insufficient information. Need to see fluid inlet at a minimum. Also a top view. What are they on presently? Piston size would be very useful also.
SierraNevada
Sep 5 2018, 10:31 PM
Piston looks to be 34mm.
[/quote]
SierraNevada
Sep 5 2018, 10:32 PM
[quote name='SierraNevada' date='Sep 5 2018, 09:31 PM' post='2645930']
[/quote]
[/quote]
SierraNevada
Sep 5 2018, 10:33 PM
Calipers are off the rear of a vented rotor 914.
914forme
Sep 6 2018, 06:21 AM
Nope not the rear of a 914 at least not the stock. Only vented calipers on the rear of the 914 was for the 914-6 GT cars. they where much like the 914-6 caliper with hand brake in the body, and had the spacers and longer bolts allowing you to run a vented rear motor. These Calipers where also used on the Ferrari 208 - 308 cars. Only issue is the bleeder valves are on the bottom when installed on a 914 trailing arm. PMB can fix that issue.
With the limited information and odd angle pictures, I would say 911 M caliper, that got shaped to the rear. Not an uncommon swap, you do loose the parking brake unless the 911 bits have been shaped also. HTH
davep
Sep 6 2018, 08:50 PM
That fluid inlet is 911 or 912 rear. You will need to remove the dust seal to get the actual piston diameter but I would guess that it is the 38mm version. So this would the normal 911 rear M caliper for vented rotors from 1969 until the 42mm version in the SC years. The hollow piston was the late version. This would be equivalent to the 914/6 caliper in piston size, and the 914/6 GT with vented rotors. You would need a 911 parking brake conversion for safety & road legal purposes.
