Bruce Allert
Jun 16 2005, 08:34 AM
Is this to be a total rebuild if a rods knocking?
I haven't gotten into this relm of 914's.... yet
But I do have Jake's video
........b
xsboost90
Jun 16 2005, 08:38 AM
depends on how scarred up the crank is. What does your rod knock sound like, does it get louder as you increase rpms, or does it only do it at idle.....
tat2dphreak
Jun 16 2005, 08:42 AM
IMHO, if the rod is knocking, anything less than a rebuild is a "ptach"
Bruce Allert
Jun 16 2005, 09:04 AM
| QUOTE (xsboost90 @ Jun 16 2005, 07:38 AM) |
| What does your rod knock sound like, does it get louder as you increase rpms, or does it only do it at idle..... |
It got louder when I increased RPM's
I can still hear Craig & Jim shouting "SHUT IT OFF... SHUT IT OFF"
....b
DBCooper
Jun 16 2005, 09:12 AM
Yes, it's rebuild time. If it's really a rod and you can hear it the crank's already damaged and there's no other way to fix it. You might get lucky and have caught some kind of piston or valve faliure early on, meaning you wouldn't necessarily have to split the case, but you'd still be well advised to go ahead and do it all "while you're in there".
