$27,000, cash or certified check
This was a barn find a few years ago in Salem Or. It had sat for 9 years and did not run. I put her on a trailer and brought her home to SC where I managed to breathe life into her.
Although I love to drive her, I enjoy working on it more and there's virtually nothing left to do. Time to move on and find another one to play with.
Pictures at: http://914.dolimpios.com/
Details:
• Marathon blue with black interior
• Originally a 1.7, but has been upgraded to 2.0 (original 1.7 engine retained)
• COA on order
• Engine runs perfectly, idles solid at 1K
• Compression on cylinders: 1-130, 2-128, 3-128, 4-125
• Body is excellent, longs and hell hole are nearly perfect
• Interior is nearly perfect. One small defect on passenger seat.
• Visors rebuilt by 914 Rubber
• Mileage is unknown
• Everything works perfectly, lights, switches, blowers, heating, etc.
• Within the past 5,000 miles the following was performed:
- Transmission rebuilt
- All transmission linkage bushings replaced
- CV joints removed, cleaned, inspected, repacked and flipped
- New clutch, flywheel and pressure plate
- New accelerator cable
- 911 swivel base valve adjusting screws installed
- All calipers rebuilt
- All brake rotors replaced
- All wheel bearings replaced
- Bushings on front swing arms and rear trailing arms replaced with Elephant Racing bronze bushings with grease fittings
- All new shocks
- Pedal cluster rebuilt
- Headlights upgraded to amazing LEDs
- Dash lights upgraded to LEDs
- Top and bottom Targa top seals, all window seals, front and rear trunk seals replaced
- Windshield washers upgraded with electric pump
- Fog lights upgraded to function as daytime running lights
- Interior rear view mirror upgraded to one with Homelink garage door openers and compass
- Exterior mirrors polished and new glass installed
- Cruise control installed
• Known issues
- Some rust on passenger side jack post support
- Some rust on battery tray
- Patched holes visible where someone had installed aftermarket mirrors
- Small dimple on front trunk lid where someone apparently close it on something
- Small defect on passenger seat
- Scuff marks on roof
• Also includes
- Original 1.7 engine with complete FI and exhaust system
- Original interior mirror and radio
- Two extra transmissions, one in good working order the other a donor for parts
- Numerous boxes of parts
