'75 2.0.
The throttle body on my car is pretty worn- big ol' groove on the inside from the butterfly plate makes it stick. As part of my quest to fix an idle that hunts down, I'm looking to replace it. I found one in good shape but it's got both the retard and the vacuum ports. Mine only had the retard port. If I get it, do I hook up the vacuum or block it off?
Or is there something else that's different between the early/late 2.0 TBs such that I shouldn't install it? I believe the part #s are the same.
