QUOTE(sdoolin @ Sep 12 2018, 11:03 AM)
Pics would help a lot. That sounds like it might be a fuel pressure regulator. If PO did not install a low pressure pump, then there would need to be a pressure regulator to bring fuel pressure down to the 3PSI(ish) neighbor hood needed for carbs.
I run three filters in my dual carbed 2056 (4 if you count the sock inside the tank). One filter exiting the tank just before the pump, one filter in line just before "first" carb, then one more in the fuel line that returns to the tank.
Carbs are expensive and idle jets easy to plug, so I believe more filters are better (plus they are cheap).
Hope this helps...
thanks for that insight, didn't know that you could have more than 1, i also have the sock (so i have 3 then).
btw, i looked through PO records, it looks like he replaced the front fuel pump once because old pump was pushing 13 psi (engine ran rich), new pump now pushes 4-6 psi.. would/could the second "filter" limit or decrease the psi further? like i said, engine seems to be running ok.. not great but ok.. so should i replace or remove second "filter"? (i keep putting "" because to me it looks like a filter rather than a regulator)
