i hope someone here can awnser quickly on this issue. i would like to get car on the trailer and being it up to helen . i dont want to pull the tank with 5 gallons of fuel in it so where can i run a new ground wire fo solid body ground to complete the circuit? late last night i was able to test pump and foumd the geoumd wite hooked up did not have continuity and therefore no corcuit therefore no firing of the pump, but touching a shock tower bolt or other body bolt we had a good connection and upon turning the key the pump primed! so - i need a 4 day solution for a different solid ground point-
Phil
pump is pulled thru the acces hole in the trunk.
