I'm going to replace my shifter coupling or "knuckle bushings" as 914rubber refers to them on my 72 that I'm converting to side shift. I found this video from Mark at Original customs on youtube.
https://www.youtube.com/watch?v=C0I5HOBvQbg
My question is mine has a roll pin that is not shown in the video. I have roll pin punches so I figured no problem but the hole the roll pin is pressed into does not go all the way through so I can't just knock the roll pin out. I thought I could use a small extractor and maybe twist it a little and pull it up a little and remove it. Unfortunately, my smallest extractor is broken so I couldn't try that. I thought about drilling it out and drilling all the way through so in the future I could drive the pin out easier but unless I can drill it exactly straight I'm afraid I'll have "slop". Why does mine have a roll pin that the video doesn't show? It definitely looks factory. Here's what I'm dealing with and I apologize profusely for the blurry pix.
Has anybody seen this or have any experience/ideas? I should have rotated the coupling so you can see the "bottom" picture better. It definitely does not go through.....
Thanks in advance,Erik
