QUOTE(Rand @ Sep 27 2018, 06:46 PM)
That's a lean condition. You don't need a decel valve to fix that right. Decel valve is a piece of garbage that didn't do anything except pacify some government bull about emissions control.
Actually, you are incorrect. The decel valve is there to soften the throttle closing when you jump out of the throttle at high RPM. Without the decel valve, the fuel injection will drop the idle speed below the point where the engine idles. Taht will cause the car to die.
The decel valve just bypasses the throttle plate when the engine is at a high vacuum. It will do nothing to lean out the mixture.
