So, this might be obvious but not to me....
1) Using 96mm KB pistons (2056cc) but can't find an orientation symbol. Is there one? I was just going to install them with the print upright.
2) I know I can reuse the flywheel bolts for a -4 engine, but can I also reuse the clutch bolts?
3) I have the Victor Reinz 2.0 gasket kit. Are both pushrod tube O-rings viton or are only the green ones vition?
4) I was going to have my exhaust and intake manifolds and heater parts cleaned in a hot tank. I can paint the outside with high temp paint, but what did the factory or members use to prevent surface rust on the inside?
Thanks
