There's a bushing under the nut that should keep the pulley from getting pinched even when you tighten the nut all the way.
Tighten it.
--DD
76-914
Sep 30 2018, 06:25 PM
Loose enough that it spins freely. It's a self locking nut so loose is OK
VaccaRabite
Sep 30 2018, 07:01 PM
it should spin freely but NOT wobble. Also, it looks like you are missing the sperm washer/clamp that holds the clutch cable in.
Zach
simonjb
Sep 30 2018, 08:10 PM
Thanks all. This is not my car - just a photo
worn
Sep 30 2018, 09:17 PM
QUOTE(simonjb @ Sep 30 2018, 07:10 PM)
Still it should be tight. If the wheel doesn’t turn freely something is wrong. If it isn’t tight, the nut may come off. As you reach a stoplight.
porschetub
Sep 30 2018, 10:06 PM
I have the 914 rubber one which is a quality part,found it floppy like the stock one ,from memory I machined half a millimeter off the bush and all was good.
