can someone tell me what the correct size is of the seal that from fender to fender across the bulkhead between engine and trunk?
jcd914
Oct 1 2018, 01:18 PM
Mine came from 914rubber and it needs to be trimmed slightly to match the fender to fender width. I believe it is the same seal as used in the front trunk and it makes since to trim to fit.
Jim]
thanks fir that info. i got mine from 914 rubber and there was 2 seals marked front bulkhead. since fitting my trunk is stiffer to closer and the rear edge above the lights sits slightly too high and there are no obstructions preventing it to lower.
