Pierce
Oct 2 2018, 02:19 PM
On my '73 914, the headlights will pop up but the bulbs do not light. Neither does the side marker lights. I have checked the fuses and they seem fine.
Is there a relay somewhere that supplies 12V to the headlights? Any suggestions?
TheCabinetmaker
Oct 2 2018, 02:31 PM
Did they work, then just quit? Try flipping the stalk switch.I've seen either the high or low beams go out, and the other work. Usually a problem with the switch.
76-914
Oct 2 2018, 03:00 PM
There is a relay for the high beam / low beam switching. Does everything else, electrical, work fine?
Front yard mechanic
Oct 2 2018, 06:37 PM
Pull the headlight relay and test the lights there by jumping the white or the yellow if they come on it's probably the switch
