QUOTE(Tdskip @ Oct 3 2018, 10:50 AM)
Ah ha!
Let me test it to see if it has power when it should be a ignition switch position.
It's powered through a relay on the relay board that is controlled by the FI brain.
So don't expect continuous voltage with the key on.
The FI brain will only power it to prime the pump and then shut it off until the engine actually starts.
