Remove the underbody POS and install a real adjustable bar.
Other ways of fixing this
Tires in square configuration
Add a rear swayer
Add more Rear spring
Reduce front torsion bar size reducing the spring rate
Reduce front swayer size - like I suggested up top.
Change shock pressures
Change tire pressures
Suspension alignment can also give you fits.
You could always go larger in the fromt and smaller in the back, Tires that is. Make it look like some of them Drag Hondas.
You can also just pull the e-brake, Oh wait its a 914
you can add a cutter brake
you can also do the same with the throttle if you have enough Torque to break things loose, or just lift that will change the orientation of your car.
Don't do the last one, unless you know what it is going to do, and need it for the situation. One of our Auto-xs they put a box on a banked section of the oval. The last run of the day I figured out if I just went into the box at full speed, I could lift and then immediately smash the throttle back down I would get through the box clean. It was designed to slow you down going into the finish. I crossed the line doing over 80 MPH. Corvette guess where pissed. 914 was just narrow enough that it would clear with just a slight rotation of the back end. Wish I figured that out 2 runs earlier. You can use the same technique at Mid Ohio.
