QUOTE(Downunderman @ Oct 5 2018, 07:08 PM)
What I want is probably what is used in F Production. What do you use Chris?
I've seen popup pistons that someone else used to get high compression without flycutting the heads too deeply, but I think that much shape on the piston crown affects the flame path too much.
Cutting the heads has its drawbacks too. Mostly because one of the exhaust stud bores is very close to a combustion chamber and may break thru when trying to get below 40cc.
My pistons were made to order by sending them a set of dimensions to work with.
Pin height, ring groove widths, piston dia., dome height & dia.
I used a stock high compression 1.7L piston as my model.
I've had 91mm pistons made for 1.7L and 94mm pistons made for 1.8L.
I cut my own eyebrows for the valves after doing a full mockup.
