Tdskip
Oct 15 2018, 07:06 AM
Good morning-hope everybody had a good weekend.
It would seem as if one of the rights of 914 ownership passages is dealing with self-loosening axle bolts.
Will the correct size spring washers from Ace deal with this, or do I need special serrated ones, or do I need to safety wire them?
Thanks in advance for the help, have a good morning.
TheCabinetmaker
Oct 15 2018, 07:38 AM
New Schnoor washers and proper torque will keep them right. Threads need to be clean
Oct 15 2018, 07:40 AM
QUOTE(TheCabinetmaker @ Oct 15 2018, 09:38 AM)
That’s the proper fix.
VaccaRabite
Oct 15 2018, 07:55 AM
Yes the new Schnoor washers and clean threads, but adding safety wire does not hurt either.
Zach
wndsrfr
Oct 15 2018, 08:00 AM
QUOTE(VaccaRabite @ Oct 15 2018, 05:55 AM)
Zach
Tdskip
Oct 15 2018, 08:08 AM
Thanks Gentlemen
914forme
Oct 15 2018, 05:06 PM
I do that, and then safety wire them. That works every time. You do that when you are younger and drive the 914 to clients. The CV fell off on my way to one of them, no problem, except hand got covered in CV grease, luckily I knew them well, not a first impression sort of thing. Still not my most professional day.
Same day I also discovered my fuel level sender was not working and ran out of fuel on the way back home. Murphy was batting a 1000 that day. Still had a huge smile on my face from
Tdskip
Oct 15 2018, 07:49 PM
Pulled one to go make sure I get the right size washers. The split washers on here for apparently useless, and the threads were very greasy
Click to view attachmentClick to view attachment
Mark Henry
Oct 15 2018, 07:56 PM
That's not a factory bolt or washer.
Oct 15 2018, 07:57 PM
That bolt doesn't look right, also, the center part of the threads is stripped ...
jcd914
Oct 15 2018, 08:00 PM
QUOTE(Tdskip @ Oct 15 2018, 06:49 PM)
Those bolts are not the original type of bolt used for 914 CV joints.
I would be ordering some new bolts and probably get the "drilled for safety wire" bolts since I was getting new bolts.
You need to be sure the bolts are the correct strength.
Jim
914sgofast2
Oct 15 2018, 08:05 PM
It’s the wrong bolt for the CV joints. They are supposed to be the riebe style, which looks somewhat like an internal multi faceted Allen bolt. As already stated, you also need the special schnorr (spelling?) style of lock washers for the bolts.
Mark Henry
Oct 15 2018, 08:06 PM
QUOTE(SirAndy @ Oct 15 2018, 09:57 PM)
Flattened, likely from banging against the loose CV.
Factory bolts /4 are only threaded part way, 8mm tri-square female. schnorr washers are thin wavy washers with teeth ridges.
914_teener
Oct 15 2018, 09:37 PM
Go buy a lottery ticket if you had that on the freeway.
Larmo63
Oct 15 2018, 09:56 PM
I'm pretty sure 914 Rubber sells the correct drilled ones.....?
Mikey914
Oct 15 2018, 10:06 PM
pete000
Oct 15 2018, 10:18 PM
Rebuilding my CV joints and noticed my car was missing one roll pin and had no schorr washers ! Replacing all the bolts, adding the washers. Amazed the car did not have any issues running just on roll pin on one of the joints. I guess low power application helps !
What is the torque spec for the CV bolts?
RenoRoger
Oct 16 2018, 03:21 AM
QUOTE(pete000 @ Oct 15 2018, 09:18 PM)
Haynes says 31lbs, others say 25 lbs
wndsrfr
Oct 16 2018, 06:05 AM
QUOTE(Larmo63 @ Oct 15 2018, 07:56 PM)
I've drilled some...not hard to do...1/16 bit and some quiet time...
IronHillRestorations
Oct 16 2018, 06:22 AM
The Schnoor washers are a one and done part, which is why we get in trouble in the early years of 914 ownership.
"Ya mean I have to get new ones every time I pull the engine?", yes.
mskala
Oct 16 2018, 06:58 AM
IMO, if you use _new_ schnorr washers each time, then having grease-free threads
is not necessary. I've installed and removed a bunch of times, I could never get the
area clean while still having grease everywhere you need it. I've checked the torque
before each autocross, they have never loosened even a little.
Bartlett 914
Oct 16 2018, 09:22 AM
I have said this and I will say it again. When the cv comes loose, it distorts the output flange. It causes the threaded holes to be pulled out slightly. This no longer allows the cv to sit perfectly flat to the output flange. This is the main cause of cv's coming loose. Remove the output flange and turn a cleanup cut on the face. The material is not hardened and it cleans up nicely. Twice my cv's came off in a years time. I discovered this issue. They remain tight to this day
burton73
Oct 16 2018, 09:44 AM
QUOTE(Mikey914 @ Oct 15 2018, 09:06 PM)
Just get these from 914rubber and be done.
Bob B
porschetub
Oct 16 2018, 01:10 PM
QUOTE(RenoRoger @ Oct 16 2018, 10:21 PM)
Do mine @ 30lbs seem to remember Eric @ PMB stated something like that,the bolts are strong enough to take it and yes make sure they and clean and inspect the threads and bin any damaged ones.
TravisNeff
Oct 16 2018, 02:05 PM
I bought a big bag of the schnorr washer from McMaster
Jeff Hail
Oct 16 2018, 06:45 PM
QUOTE(Tdskip @ Oct 15 2018, 06:06 AM)
"spring waters "?
[b]Self loosening axle bolts-will spring waters take care of this?
[/b]
Sure as natures Lock-Tight it will help. A little rust will keep them from backing out.
jfort
Oct 16 2018, 06:59 PM
My notes to myself:
Axle bolts: 6mm Allen (after market wire drilled) on the inner side, 8mm 12 point on the outer side. Torque to 30 ft-lbs
jim_hoyland
Oct 16 2018, 07:43 PM
