milwlandrover
Oct 19 2018, 07:50 AM
I am looking for a tachometer cable. when doing the transmission I found my original cable wrapped around the axle. I had to cut it off and I can not find a replacement cable or any tech info on how to replace it. I found lots of speedometer cables when I input tachometer cable in the search but that is not what I need. Any ideas out there?
thanks and cheers!
mgphoto
Oct 19 2018, 08:10 AM
Tach is electronic, no cable, just a single wire from the coil.
Speedo cable, accelerator cable and heater cables, that’s it.
TheCabinetmaker
Oct 19 2018, 09:20 AM
It's a speedo cable
milwlandrover
Oct 19 2018, 09:54 AM
My speedo is working really well. The tach is not, that is why I assumed the cable wrapped around the axel was for the tach. But that answers why all my searches for the tach cable were fruitless
I suppose the best place to start would be to remove the tach for inspection.... correct?
ChrisFoley
Oct 19 2018, 09:59 AM
How about a picture of the cable you removed? Was it on the driver side? Could it be the backup light wires?
The tachometer is driven by a thin black/red wire attached to the negative terminal of the coil.
milwlandrover
Oct 19 2018, 11:17 AM
the cable was so damaged I just tossed it. It was on the passenger side of the axel. I can look a little closer tonight. Perhaps I will see a loose end of the original cable but I did not see anything when I did the brakes.
mgphoto
Oct 19 2018, 03:39 PM
QUOTE(milwlandrover @ Oct 19 2018, 10:17 AM)
Could be e-brake cable, one on either side, maybe just long enough to reach the axle?
rgalla9146
Oct 19 2018, 05:33 PM
Check the arm on the bottom of the pass. rear caliper, is there a cable attached to the trailing arm and the caliper ?
